This VI claims to be part of a library, but the library does not claim to own this VI.
I am having a reoccurring issue with "This VI claims to be part of a library, but the library does not claim to own this VI." I can work around this by disconnecting the vi from the library and then saving it back.
However, I cannot access some vi because I don't have a password. Sub-vi's are not executable and I am thinking this is due to the issue first mentioned. For example, after relinking to a library the vi in question is now having class conflicts. I cannot modify this vi to fix it.
I believe this issue is responsible for certain functionality of my project to work for months on end and then suddenly the functionality stops working. After investigating, I find that there is an issue with some .lvlib, and using a different vi from that library will solve the issue (for example, switching from standard report to html report). I think this may be related to "This VI claims to be part of a library, but the library does not claim to own this VI."
This seems to be happening since installation of version 10.
Help!
(2,905 Views)
What version of Labview were you using before you upgraded to Labview 2010?
Eric
Eric Liauw
Senior AE Specialist - Automated Test | CLD | CTA
(2,861 Views)
