ThorLabs Communication
Ok so I fixed the blocking issue. It was the termination stuff of the property node. My bad...
Still having an issue with the writing though. Got error -1073807339 for the VISA Write. Any ideas?
SM
Message 21 of 25
(1,315 Views)
That is a timeout error.  I have never seen that for a VISA Write.  That is typically coming from a VISA Read.
Are you sure about the source of the error?
Message 22 of 25
(1,309 Views)
Yes, I checked it again. It is in fact coming from Visa Write. It will set there blocking for I guess 1 second, and then move on. Is the way that I'm trying to send the message taking too long or something? Or is it just that it's not sending it at all?
SM
Message 23 of 25
(1,306 Views)
Maybe something is wrong with the driver they provide and VISA is not communicating with that.
Do they have any software that you can try using to see if your PC is able to communicate with it through that?
Message 24 of 25
(1,303 Views)
Yes I have been able to use Kinesis and some APT DLL files, they worked good. But now I'm trying to do it without DLL files, and just use VISA. Why would they put in the manual of how to send messages if there wasn't an option?
SM
Message 25 of 25
(1,300 Views)
