ThreadIberr()
While using GPIB write I am able to commuicate with the tool but consistently get - ThreadIberr() - this causes an error on the next read or write command. The error is undefined. What next???
(3,174 Views)
The Threadberr is used in multi-thread GPIB applications to check thread status. you can find more information on this function in the "NI-488.2 Help" file. You probably used a thread status variable instead of a global status variable which causes the error.
You can also attach the SPY capture of the error so we can take a look at the "undefined" error you received
(3,153 Views)
