Three conditions in real time signal
Hi, can anyone suggest how to make three condition? I have t value that changes in time and I need to exclude three cases. condition.jpg
Message 1 of 8
(4,008 Views)
You should not follow that strict flow chart. You should use a case structure to distinguish the different states.
Regarding the LED color: The value of a LED is boolean: It is ON or OFF.
But the color is an arbitrary RGB (numeric) value. So you can change the ON color to RED, YELLOW or GREEN. After setting that color, you can turn on the LED (set its value to TRUE).
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(4,005 Views)
I would use something like this VI I made a long time ago to as the input to a case to turn on proper LED.
Notice the "=" is not the standard "=" primitive. Search for rounding errors and machine epsilon and you will see why I used it.
But in a nutshell remember when comparing non integers 1.0000000001 and 1.0000000000 are NOT equal!
=== Engineer Ambiguously ===
Message 3 of 8
(3,998 Views)
Can you send me that Labview file?
Message 4 of 8
(3,969 Views)
The image RTSLVU posted is a "snippet". It contains the code. It states version 2015, so you'll need LV 2015 to load it.
Norbert
Norbert
Expert: Geometry
Message 5 of 8
(3,959 Views)
What LabVIEW version are you using?
Message 6 of 8
(3,954 Views)
2014 version
Message 7 of 8
(3,932 Views)
Here you go.
Message 8 of 8
(3,921 Views)
