Three devices with one computer
Hello everyone. Can i make a labview program with three scales ?. They must all be connected with a serial port connection.
Best regards
Oesen
(3,450 Views)
Hi oesen,
                 Can you explain your question more clearly?
Thanks as kudos only:)
(3,448 Views)
Yep more details would been nice. But when your PC has 3 serial ports you can communicate over all of them:-)
(3,439 Views)
Yes off course.. I have to make a program, which lets my PC communicate with three devices at the same time. Is this possible even though all three scales are communicated with a serial port ?. As far as i know, serial port connection can only communicate with ONE device, and not MORE device at the same time ?
Best regards
Oesen
(3,433 Views)
Not One device, The serial port sends and receives bytes of information one bit at a time.Based on the number of ports available in your system you can communicate with any of the devices.
(3,429 Views)
Yes, you will need 3 serial ports, each one connected to one device.
If your PC does not have 3 ports you have several options:
- use a PCIe card with additional serial ports
- use USB to serial adapters
- there's also a box from NI which converts one USB into 4 serial ports
(3,428 Views)
