Threshold Detector.dvi
Good afternoon. I'm working on a USRP (BasicUSRPLabs) lab. One of the works uses the block FrameSync(Real).gvi for synchronizing bits on the receiving side. To work with it, you need the files Normalize Vector.gvi and Threshold Detector.gvi. The normalization block is available in additional files for laboratory work, but there is no Threshold Detector.gvi block. Does anyone have such a block or where can I find it?
(513 Views)
Hi Fauzen,
@Fauzen wrote:
Hello. I'm working on a USRP lab (BasicUSRPLabs). One of the labs uses the FrameSync(Real).gvi block to synchronize bits on the receiving end. To use it, I need the Normalize Vector.gvi and Threshold Detector.gvi files. The normalization block is available in the lab's supplemental files, but the Threshold Detector.gvi block is not. Does anyone have this block, or where can I find it?
Did you know you ask in a world-wide forum, mainly using English?
On your question: "gvi" files typically are used with LabVIEW-NXG, which is end-of-life/deprecated several years ago. I don't think you will get much help with this anymore.
I recommend to switch to a recent LabVIEW version…
(494 Views)
