Threshold peak detector for digital data
I have a graph that shows me the digital input, 0’s and 1’s, I am getting across time.
Now I want to select data and just take for example consecutives 1’s that have been detected for at least 3 seconds. I found a function that can do that: the Threshold Peak Detector VI, but this is for analog data, isn’t it? Can anyone tell me if there is a function that can do what I need and it is working for digital data?
Thanks in advance,
Carola
(3,790 Views)
Has all the data been acquired when you want to find the sequence or do you need to do this as data is acquired?  If all the data has been acquired, you could try using the Search for Digital Pattern VI to look for a rising edge (0 to 1 transition) followed by three seconds worth of 1's.  This would require converting the data to a digital waveform or digital data if it isn't already, but that's easy to do.
(3,775 Views)
Thanks for your answer.
I need to do this while I am acquiring the data, which is already digital.
Carola
(3,765 Views)
If you need to detect it as the data is being acquired, take a look at the attached VI for a possible technique.  You can replace the switch with your acquisition, remove the delay, and replace the LED with whatever you need to do when the event is detected.
(3,758 Views)
Thank you very much! ...but I cannot open it, I have the LabVIEW version 10.0.
(3,756 Views)
Here is the same VI saved for 2010.
(3,751 Views)
It is working! thanks a lot!
Carola
(3,745 Views)
