Thresholding an array
how should we threshold an array
say i have and array 1 2 3 4 5 6 and i want to store the numbers 4 5 6 into another array how do i do it
(4,062 Views)
Hi kst,
you can do it with the "array subset" function.
Mike
(4,057 Views)
Assuming by threshold you mean keep the values above a certain value, it is often a simple job for the bucket brigade.  Here is my ready-made snippet for this common problem.
(4,046 Views)
thanks Darin,
or like this.
Mike
(4,038 Views)
wat is does your vi look like in the false side. can you attach you files i mean .vi file to the reply
(3,963 Views)
hi mike where can i get the threshold peak detector.vi file is it available online
(3,961 Views)
