TiScan Issue
I'm using a TinScan to view 16 Thermocouple channels (0-15) using a PCI-773 and labview 7.  When viewing my front panel I want to set the low channel to TC# 1 and read channel 0 from the board and make adjustments from the high channel up to TC#16 which is channel 15 on the board. I don't want an operator getting confused thinking there reading channel 1 and its actually channel 2 due to the offset by 1.I tired adding various functions to my block diagram but have been unsuccessful.
I attached a copy of my progress
Thanks for all your help.
Itspop
(3,180 Views)
The only function you need is this one. Use one each between the terminal and the input to the subVI. You should really think about taking a class on LabVIEW. Look at the recomendations tst has made here.
Message Edited by Dennis Knutson on 01-25-2007 12:31 PM
Message Edited by Dennis Knutson on 01-25-2007 12:32 PM
(3,170 Views)
Thank you for your input, I resolved my problem.
Lin
(3,144 Views)
