Tick colors Property node bug
I found a bug in 8.5 tonight.  The attached VI will demonstrate the issue.
If you attempt to get the Tick Colors by cluster, you will get an error indicating that the property doesn't exist.  If you get the Tick Colors by individual name, you won't get the error.
This applies to all plot types.
Message Edited by Matthew Kelton on 12-30-2007 02:30 AM
(3,684 Views)
This was reported to R&D (4BA3OC8G) for further investigation. A possible workaround is bundling all the separate elements yourself.
Thanks for the feedback!
Charlie M. CLD
(3,660 Views)
This is a 3 year old bug that still seems to exist in Labview 2010 (see attached).  Let me know if there's a better place to report this.
(3,226 Views)
Hi bracker,
Thank you for the bug report.  I can confirm that I'm still seeing it in LabVIEW 2010 as well.  I will pass along your feedback - even though there's an easy workaround, it always helps to know when customers are affected so we can prioritize these issues.
Morgan S
(3,193 Views)
