Tick count
What is the problem?
Here I attached the image. Try similar
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 17
(1,228 Views)
it is still not turning on after 15 seconds. And please can you explain how did you calculate the elapsed time.
Message 12 of 17
(1,223 Views)
They are not good examples.  It relies on the difference in time stamps to be exactly a multiple of 15,000 milliseconds apart.  (time/15,000 has remainder=0)  There is no guarantee that will happen.
You should just use the elapsed time Express VI.
Message 13 of 17
(1,217 Views)
But please explain to me why did we use a for loop and why did we substract the two counter values?
Message 14 of 17
(1,215 Views)
Because you wanted something to happen after a specified time interval. You can't have an interval without an initial and final/current measurement.
To see if TimeB is 15 seconds after TimeA, the difference between TimeA and TimeB needs to be calculated.
Message 15 of 17
(1,205 Views)
That's not For loop, That's while loop. ( use it to run continiuosly unless you stop )
Timer value difference means the time you started something and what is the current time so you are measursing the time elapsed.
I would recommened basic courses of LabVIEW for you.
Message 16 of 17
(1,203 Views)
Becasue The base reference time (millisecond zero) is undefined. Hence when VI starts then we are taking one ms value and later we subtract the value from first timer. Hence subtracted reference value will be time from VI runs
--Ranjeet
Message 17 of 17
(1,203 Views)
