Tie Scrollbars together
Capture.PNGMy program is coming together really well functionally and now I need to dress it up a bit. I have 5 array boxes with scrollbars that I would like see get adjusted from any one of the boxes. Is it possible?
(3,800 Views)
Yes the easiest way to do this is to create a new vertical scroll bar, then have an event structure get triggered on a value change, and then using a property node set the index value of all the array controls, to the value of the vertical scrollbar.  You can then hide all the other vertical scrollbars on the other controls.  You'll also need to set the scrollbar size to the number of elements in the array.
(3,790 Views)
I'm with you up until the property node settings. I don't see how to set this up.
(3,781 Views)
Accepted by topic author RHutchings
Sure thing, here is a demo.  When it is working you can obviously hide the scrollbars on each of the controls.
(3,755 Views)
Thank you very much.
(3,729 Views)
