Time Aligning Two Datasets
Hi All,
Searching on the NI Forums to find a way of aligning two datasets didn't give me what I required, so to detail the issue:
  • I have two sets of data.
  • Both datasets have the same measurement channels
  • I want to plot the datasets against each other.
  • The datasets have different recording lengths so there is an offset in the X-Axis time period.
  • I want to try to align the datasets to overlay specific sections that are identical to each other.
  • I wish to do this using either a time-based X-axis or a logpoint-based X-axis.
Other programs such as Bosch MDA and Uniplot have this feature built in where data alignment is done with a simple, easy drag and drop on the X-axis. I'm surprised that Diadem does not have this.
(2,473 Views)
Wrong board? The DIAdem board is here.
Certified LabVIEW Architect
(2,446 Views)
Ok, thanks.
(2,431 Views)
