Time Coded Analog SIgnal
Hello Alipio,
I wired the origional version to my DAQ device, it worked but the trigger would not reset some some readings were inaccurate.  Also, I have two devices with this signal on two seperate channels on my DAQ.  I will wire in this new code to the DAQ and give it a test run.
Brian
Message 11 of 19
(1,732 Views)
Hello Alipio,
I used the updated code, much better.  Thanks this is fantastic!  I scaled the anolg signal output signals to their respective values and the reluslt are good so far. I have a  question.  What is the best way to run two sets of these loops (the Producer Loop and Consumer Loop)?  I used the code for both devices and since they basically gave the same signal, differing only in amplituce for the 5 signals, the results were the same-it worked.  Thank you for your help with this project.
Brian
Message 12 of 19
(1,714 Views)
Hello.
Probably, you will need only a producer loop adquirig 2 channel simultaneously. Then, separate the channels to  fill 2 different queues.
In that way, you will need to duplicate the consumer loop to have the tu signals processed. To avoif  probelm wiht subvis, make a copy of every subvi and rename it or try to make then reentrant.
If have problems, Next week iI will try to make it for you.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
Message 13 of 19
(1,702 Views)
Hello Alipio,
I have not had time lately to try your suggestion for using two different "time coded" signals in one LabVIEW program; shift in projects.  I am now back to continue and finish this project so I should be able to attempt it later today or tomorrow.  Thanks again for your help.
Brian
Message 14 of 19
(1,658 Views)
Hello Alipio,
The code works for the two devices that have this signal, perfect.  Now I need to develope a program that can incorporate at least two such deivces with this signal pattern.  I tried to make a sub vi on the code you had written but no luck.  I made a simple program with a DAQ assistant to bring in data then connnect the data to my a signal in terminal on the sub vi.  How can I make the code work so I have a sub vi, or is it easiser to modify the current code to accept two such signals.  I am pushing for the sub vi because I have several 4-20mA analog signals in the program (temperature, pressure etc).
Thank you for your help!
Brian
Message 15 of 19
(1,554 Views)
Here is the sample code.
Message 16 of 19
(1,553 Views)
Hello.
No problem to use the code for various channels. You have to code the processing part as a subvi and make it reentrant.
I have no Labview on hand right now, so I will try to look yor code in 2 or 3 days.
Will post back when solved.
Cheers
Alipio
Message 17 of 19
(1,544 Views)
Alipio,
Nice, thank you for your help.
Cheers and have a good weekend,
Brian
Message 18 of 19
(1,478 Views)
Hello.
I have no labview.
I will try to get one as soon as posible.
In the meanwhile, you can try to make a subvi of processing part and make it reentrant.
Cheers
Alipio
Mensaje editado por alipio
Message 19 of 19
(1,468 Views)
