Time Dependant Smoothing or Filtering
I have a waveform which I am plotting on a log(x) scale and would like to accordingly filter this data such that it smooths the larger x values much more than the smaller ones.
I am strugling to find anything that will do this, are there any VI's that would do this for me?
Chaz
(2,664 Views)
Hi Chaz,
Are you able to send your code over so that we can take a look at what you have implemented so far?
It may be best to separate your waveform and perform filtering independently on each section.
Marshall B
National Instruments UK & Ireland
(2,634 Views)
I think you may have to "roll your own".  When you do a log(x) transform (for example, a Bode plot with log(frequency) on the X axis), the number of points-per-unit-X-axis increases as you go to the right.
Think about smoothing an "ordinary" (not-log) plot.  One way to do this is to divide the X axis into, say, 100 equal intervals (I'm assuming you have 1000 points) and replace all of the points with the average within each interval (like a histogram).  You can also take this 1% window and slide it along the X axis, averaging as you go, the so-called "moving boxcar average".  Note that if the X axis has width W, each bin would have width W/100.
You can do the same thing with your log plot.  The difference is that instead of dividing the X axis into 100 intervals, you divide the log-X axis into 100 intervals.  Now the width of the bins is not W/100, but the 100th root of W.
This should get you started, I hope.
BS
(2,611 Views)
