Time Issue in Subvi
I have a subVI that activates a DAQ, and I do it dynamically (Please see picture attached).
The problem is that the first time I run it, it takes a very long time.
Is there a way to make it faster?
Thanks so much in advance,
(1,275 Views)
Looks like you wired the 5 to the Timeout
Qestit Systems
Certified-LabVIEW-Developer
(1,270 Views)
😲thanks so much!!
(1,262 Views)
I have removed the timeout but the first time I run it it still takes a long time... 😞
(1,252 Views)
Hi Elfernro,
The first time you run the VI it needs to initialize the whole DAQmx stack.
You explicitely request all available DAQmx devices…
You might re-organize your whole VI/project so you do the initialize stuff right after start of the main VI.
That subVI should get the required channel (including the DAQmx device name) as input…
(1,245 Views)
Hi Gerdw,
thank so much for your time.
But the subvi always waits (the first time I run it along time) on "Start Task", even if I use fixed  input channel. Can I avoid that?
(Please see attached picture)
Thanks so much!!
(1,217 Views)
