Time Scale Generation
Hi folks, I need some help out here!
I am using Labview 5.1, an ATMIO DAQ card series and Windows95. I am
successfully reading the voltage output of two pressure transmitters and
saving these outputs into a file in ASCII mode in two separate columns
V1 and V2. So far I am opening the generated file in another software
application to generate the time-scale column to plot V1 or V2 versus
Volts [Volts X milliseconds] by dividing the total acquisition time by
the number of acquired points. Usually I am generating files of 1800
points with scan rates of 600 Hz (3 seconds total). I would like to get
some help on how to generate the time-column and save it together with
the other two signals in the same file. Furthermore, I would like t
o
know if the error I am causing by artificially generating the time-scale
using other programs is considerable or not when compared to the
time-scale that would be generated using the DAQ itself.
I am attaching the VI I made.
Thanks in advance for any help!
Sergio Ricardo Pereira Perillo
MSc. Nuclear Engineering
Instituto de Pesquisas Energéticas e Nucleares IPEN-CNEN/SP
Monitoring and Diagnosis Division
Travessa R, 400 Cidade Universitária
São Paulo-SP
CEP:05508-900
Brasil
Fax: +5511 3816-9432
Telefone: +5511 3816-9164
[See first answer for additional information]
(2,900 Views)
[Attachment(s) for question]
(2,900 Views)
