Time Stamp read problem with Spreadsheet String To Array
Hiii, David
        Let me take you out of confusion, i also explain in the post that actually the thing which RolfK has done has already been done by me, but the thing is array is giving me all the channels values in a single plot, which i dont want and here i also have try to plot the clusetrs of both, but in that i was also unable,user want sixteen different channels as sixteen different plots on the graph, and which is not posible with the array, it is only possible by the clusters, and thats why i am not preferring Rolf's vi, and i always appreciate the efforts of Rolf,but the thing was not useful for my project, another thing here i am attaching the vi and the jpg file of the data in the waveform chart, which shows how i want the data in the graph, and if possible please change the Rolf's vi that way, and Rolf i am also Requesting you to please change the vi for the clusters of data instead of array, if possible please, please do it for me.
Nishant
Message 51 of 60
(2,501 Views)
Hii, David and Rolfk
         David please, please, please send me the vi in ehich you ve shown the date from the relative time vi of "Time Abs vs Rel.jpg" figure, please, send me so that i can make something out of it, i ll be in a big loop, if i couldn't make this. please.
Nishant
Message 52 of 60
(2,499 Views)
Message 53 of 60
(2,496 Views)
Hiii, David
            Absolutely, that was a great method and so simple to convert, but as u can see my file is tab delimited file and saving the data into the string format, so whenever i ll read the data, it will be in the string format, and the method which we r using for the conversion of Date/Time is in the Numeric, so the initial question is of converting the string values into the Numeric, as we convert the time, but this time it is for the date and time, then what should i do to convert it into the numeric?
Nishant
Message 54 of 60
(2,490 Views)
You can use what I supplied in Reply#18 just wire the output from the compound addition to a numeric indicator and format it accordingly.
Message 55 of 60
(2,487 Views)
Hiiii, David
         Thats true to format ir accordingly, but it was only for the time, and this is the datea and the time, so i dont know how to do conversion for that as u ve done in the vi of Reply#18, can you please help me?
Nishant
Message 56 of 60
(2,480 Views)
OK so take the bits you need out of Reply #7.
Message 57 of 60
(2,476 Views)
Hiii, David
          Nishant gives you a hearty thanks man, you have solve most of my problem, i m now facing only the problem of cursor, and for that as i wrote in the vi ahead, if anybody can convert those arrays into the clusters as in the vi of Reply#51, then it is almost complete, coz then in the XY-graph i can show the data with whole 16-channels differently, instead of one, and then there is a cursor in that.
Nishant
Message Edited by Nishant on 02-08-2006 05:17 AM
Message 58 of 60
(2,473 Views)
Hello, David,
I created a new message subject but never saw you there?
I am the person that asked about the notepad and MS Access?
Thanks in advance for your help:)!
Message 59 of 60
(2,457 Views)
Didn't spot it. Reply with the link to your post.
Message 60 of 60
(2,451 Views)
