Time Stamp to number
I am able to convert the number to time stamp as per attached snippet. I want to do the reverse operation like time stamp to number. Kindly help me to get the system time and convert to number. And if I give that number as a input to below code that should show the exact time of that number.time.png
S Nagaraju
(3,777 Views)
Accepted by topic author Sonti_11532
Hi sonit,
when you talk about "timestamps" you should actually use them:
(3,756 Views)
Thank you for the replay.
Same time is demonstrating in string format but i want in number.
Anyway i used the "To Double Precision Float" function and it working.
S Nagaraju.
(3,748 Views)
