09-12-2024 07:15 AM
I have two inputs of time stamp control "from" which is a starting date, and "to" which is an ending date I want to list out the dates which will lie between them. Can anyone give me some snippet or algorithm through which we can list out the dates?
09-12-2024 08:05 AM
Very brutal solution, but it works. If this is what you want.
I'm sure there are some edge cases that you should check (leap seconds and leap days maybe?).
09-12-2024 08:05 AM
Hi sesinfo,
What have you tried and where are you stuck?
09-12-2024 08:07 AM
Start with the first date and continuously add 86400 (seconds/day) to get each day until you are past the last date.
09-12-2024 09:57 PM
That won't always work due to Daylight Saving switchovers.
09-13-2024 08:50 AM - edited 09-13-2024 08:53 AM
That's why I just tell ChatGPT to do it for me in python, then call a python node 😂
Aint no body got time to think about that
from datetime import datetime, timedelta
import pytz
def list_dates_between(start_date, end_date, timezone_str='UTC'):
# Set the timezone using pytz
timezone = pytz.timezone(timezone_str)
# Ensure the start and end dates are timezone aware
start_date = timezone.localize(start_date)
end_date = timezone.localize(end_date)
# List to store the dates between the two timestamps
date_list = []
# Loop through each day and append to the list
current_date = start_date
while current_date <= end_date:
date_list.append(current_date)
current_date += timedelta(days=1)
# Return the list of dates
return date_list
# Example usage:
start_date = datetime(2024, 3, 10, 0, 0) # Day before daylight savings in US
end_date = datetime(2024, 3, 15, 0, 0) # Day after daylight savings starts
timezone_str = 'US/Eastern'
dates = list_dates_between(start_date, end_date, timezone_str)
for date in dates:
print(date.strftime('%Y-%m-%d %H:%M:%S %Z%z'))
09-13-2024 02:33 PM
Aint no body got time to think about thatfrom datetime import datetime, timedelta
import pytzdef list_dates_between(start_date, end_date, timezone_str='UTC'):
date_list = []
return date_list# Example usage:
timezone_str = 'US/Eastern'dates = list_dates_between(start_date, end_date, timezone_str)
for date in dates:
I don't trust deranged bots. Here's how I would do it:
09-15-2024 01:53 AM - edited 09-15-2024 01:56 AM
Just for fun, here are a couple of other ways. I haven't checked if they handle DST transitions correctly.:
