Time change to stop and start writing to a file
Guys,
I'm trying to stop writing to a file at 12:00 AM and start writing to a new file when it gets to this time. I also need to start writing to the same directory. How can I do this. I beleive I know how to do it with a close and open file but i'm still learning these functions. Attached is my code.
(2,660 Views)
Duplicate thread. Have you tried the last example I posted there? Is there some problem with it?
(2,640 Views)
You were getting help on this problem in your other thread. It usually is best to continue the active one rather than start an all new one for the same problem. If the answer(s) you get in the other thread don't help, specify why and the original poster, or others will usually add detail to their answers. Starting a new thread usually results in repeated work, as the respondents may not have seen what was proposed in the other thread.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,638 Views)
Sorry to repost the question again but since I had asked a seperate question I thought it may be better to repost another message in hopes of receiving more feedback. I apoligize and it wont happen again.
(2,630 Views)
