Time controlled Loop faster than 1ms
HI
I work with Labview 8.2.1.
I need a time controlled loop who is faster than 1ms. I tried to use the 1MHZ time source (see picture) but the loop does not work with this.
Please help
Message Edited by SteffenGrab on 11-30-2007 01:13 PM
Message Edited by SteffenGrab on 11-30-2007 01:17 PM
Message 1 of 24
(6,830 Views)
There is no picture to see...
Message 2 of 24
(6,827 Views)
Is this LabVIEW RT?
Message 3 of 24
(6,824 Views)
It is not RT
Message 4 of 24
(6,820 Views)
NI PXI chasis' have a built-in 1MHz timing source.
With a proper hardware timing source, I have run timed loops at 2KHz under Windows without any iterations finishing late.
Ben
Message 5 of 24
(6,792 Views)
I have no NI Hardware
Message 6 of 24
(6,768 Views)
"I have no NI Hardware"
Sorry to say this but Steffen, but without an RT platform, or a hardware imterface,
your efforts will be an exercise in futility.
Ben
Message 7 of 24
(6,759 Views)
     Just for clarification, you can not go faster than a ms time clock due to the limitation of Windows.  Since you are running on a non-RT system and running it on a Windows machine (and Window's clock is based on a ms time structure) you can not go faster than it.
Michael B
Message 8 of 24
(6,643 Views)
You definitely need the right HW and LV-RT for that... as mentionned by Michael, Ben & Altenbach..
RayR
Message 9 of 24
(6,637 Views)
Ok
is it possible to run the Loop faster with NI Hardware but without RT?
When it is possible, please give me a example to program this.  I have USB 6211.
Message 10 of 24
(6,326 Views)
