Time difference
Hello all ,
Two Different time values in string format to be subtracted. Result to be displayed as a string
time 3 = time 2 - time 1
need your guidance and tips
(3,844 Views)
Can you be specific what is your time format in string ? e.g 10:43:16
CLD Using LabVIEW since 2013
(3,843 Views)
Essentially you will use Scan From String to convert your time strings to Timestamps, then subtract the values (you may need to convert to DBL first), then you can format the resulting DBL value to a string using Format Into String. The LabVIEW help has info on the format codes for Timestamps:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/string/format-codes-for-the-time-fo...
(3,831 Views)
Hi kartik ,
time format i needed was hours and minutes . E.G :  18:43  - 12:31
(3,826 Views)
Dear willcan
I guess this vi will help you.
(3,817 Views)
Your minutes are actually show the number of seconds after the hour.  You need another Quotient & Remainder to divide by 60.
OR
You can eliminate a lot of that code by just using the Format Date/Time String.
(3,783 Views)
When I come across a solution to something, I try to make it generic.
Drop the .xnode file onto your BD.
Right-click (or click with the Operate tool) and you can change the mode and the string format.
(3,761 Views)
