Time duration numeric format
Hi all,
I want to format a number in seconds as a time duration (hh:mm:ss). It must
not be formatted as an absolute time, therefore a number of zero should not
give "02:00:05" in the formatted output. It is a duration, therefore a
number of 40 (seconds) should be formatted as "00:00:40", 70 should be
"00:01:10", etc. I want to use this in a control on the front panel to
input a time duration.
Is this possible in LabVIEW? Any sugestions?
Gys van Zyl
(3,117 Views)
Two solutions come to mind, illustrated in the attachement.
Good luck.
(3,117 Views)
Look at using the format called Relative Time.
Greg McKaskle
(3,117 Views)
I can't believe I missed it. I kept looking for settings under "Date &
Time" format!
"Greg McKaskle" wrote in message
news:3DC094F1.2010901@austin.rr.com...
must
not
> Greg McKaskle
(3,117 Views)
