Time format for "Export Waveforms to Spreadsheet File (1D)"
Good afternoon,
I have been using "Export data to excel" through waveform graph to record data (see attached 1.tmp, attached VI). I want to use "Export Waveforms to Spreadsheet File (1D)" - however the output format doesn't match.
Can I make output format for this function match the one that is default for "Export data to excel" (4 column, relative time stamp)?
Mike
(2,988 Views)
Here are the missing files from above. Extensions are .txt
-Mike
(2,986 Views)
For including multiple time stamps, you can wire a true constant into Export Waveforms to Spreadsheet File's "multiple time columns?" input: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/waveform/wdtfileio-llb/export-wavef.... For setting up relative time with waveforms, I suggest you refer to the following document: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KZrSAM&l=en-US.
Brian.D
NI Product Owner
VeriStand
(2,942 Views)
