Time format with scan from string function
Hi all, I have next code:
When I run, I have next output:  4:03:08.000 PM 3/16/2022. Does anyone know why I have a "4" at the beginning of the output? How can I fix it?
Thanks for any help
(2,893 Views)
What time are you expecting?
Are you using UTC time or local time?
Are you using daylight saving time?
George Zou
(2,884 Views)
Hi George,
Thanks for your help
I am using local time and also using  daylight saving.
(2,867 Views)
Accepted by topic author EDGAR_PLATRONICS
Your format string should be:
%<%m/%d/%Y %I:%M:%S %p>T
(2,865 Views)
I'm not sure why it causes 4 PM but I think "%h" is wrong. Lower case h isn't listed in the format codes so it's hard to know what it's doing. Since you have 12 hour time you probably want "%<%m/%d/%Y %I:%M:%S %p>T" as your format string. %I is 12 hour time, %p grabs the AM/PM.
(2,856 Views)
Thank you George, problem fixed. After reading help, I found %I is for 12-hours format and %p is for AM PM flag. Thank you again.
(2,839 Views)
Thank you
(2,837 Views)
