Time in X-Axis. Now what am I doing wrong?
I fight with this every single time I have to make a char/graph in LabVIEW that has the current time in the Y-Axis.
I did the proper setup, right? I want an hours span starting with the current time and measurments are taken every 10 seconds.
But here is was it looks like on my screen, notice the X axis starts at 16:00, goes to 19:34, 20:34, and then ends at 9:40?
BTW only 30 seconds of data was taken on this run.
I just do not understand how this can be so difficult.
=== Engineer Ambiguously ===
(3,175 Views)
Accepted by topic author RTSLVU
I think you have the offset and multiplier inputs swapped.
Also, don't set the x-axis to autoscale.
(3,151 Views)
Right again altenbach.
I still think this is a lot harder than it should be to do.
(3,140 Views)
