Time out for While Loop
@GMAch wrote:
is there any option to stop a while loop (or force it to start the next iteration) if the the execution time of the VIs in the loop exceeds a certain value?
The answer is NO.
You will have to fix the function that is hanging such that is no longer hangs.
Edit:
You could invoke the hanging sub-VI using "Start Asynchronous Call" and then use a "wait on Asynchronous Call" where you have configure a timeout. Then you could abort the call.
Ben
Message 11 of 11
(453 Views)
