Time out in event structure
You won't. As i stated in my post way ago: VISA read/write have a configurable timeout on their own!
Norbert
EDIT: So please simply delete the "observer" loop as it is completely unnecessary.
Norbert
Expert: Geometry
Message 11 of 13
(642 Views)
@mnx wrote:
Thanks crossrulz..:-)this I have to put in 2nd while loop is it??.. And how will I monitor the timeout??
No second loop needed.  No first loop even needed for that matter.  This code will replace both of your loops.  Doesn't that look so much easier?
The VISA Read will throw an error if there is a timeout.  That timeout value is whatever you set when you configured the serial port.
Message 12 of 13
(638 Views)
Message 13 of 13
(592 Views)
