Time stamp conversion and graphs from array data
How can you read time stamps and data currently in an text file as an array and split in for display on a graph. I think I need to convert the time stamp back into seconds to do this but not sure how to do so?
(2,635 Views)
If you're using 8.2, the Read From Spreadsheet File VI can read string files. If not, you will need to open the VI and read the instruction on the diagram for how to change it.
Once you have your string array, you can use the VI found here to convert the time column (note - read the thread) and convert the second column using the String to Number functions.
___________________
Try to take over the world!
(2,622 Views)
