Time stamp not recognized by Excel
Which constant are you referring to? The 126298800 value? If so, then yes, you would need to change it since you hard-coded the subtraction of 5 hours, which is your offset from GMT. In Japan your offset would be different.
Message 11 of 16
(1,088 Views)
Yes, that is the constant I am talking about. Is there another way to do this so I don't have to change it?
gasseous
One test is worth a thousand expert opinions
Message 12 of 16
(1,086 Views)
Hi gasseous,
You could read the time zone from Windows, then use an appropriate offset.
Cheers,
Brian A.
Message 13 of 16
(1,059 Views)
LabVIEW can directly return the offset from UTC with the specifier <%z>
Ton
My LabVIEW Ideas
Message 14 of 16
(1,047 Views)
Ton,
Thank you for this information. I shall try it and see how it goes. I assume that this means I can do away with the adding and dividing of constants?
gasseous
Message 15 of 16
(1,040 Views)
The "adding and dividing" of constants has nothing to do with the offset from UTC. As I explained here, it has to do with the fact that LabVIEW measures time from a different starting point that OLE dates. Also, OLE date are in terms of days, but LabVIEW is in terms of seconds. The offset from UTC simply changes the value of the constant, not its need to be there.
Message 16 of 16
(1,024 Views)
