Time stamp with 0 as time
 I am developing a program to search by date.  I am using the time stamp control.  The problem is when I select a date it outputs the current time as well.
How do I set the time to 0?
Dan Shangraw, P.E.
(4,964 Views)
Time = 0 has a special meaning.  It is the epoch for LabVIEW which is Jan 1, 1904 Midnight GMT.
What do you want time = 0 to mean for you?
You can edit the display format properties for time stamp controls to turn off the time or date from being displayed.  You can also set a double numeric indicator to show times and dates as well.
(4,948 Views)
Accepted by topic author ASTDan
There are a couple of functions in the Timing palette you should have a look at.  They convert a timestamp into a cluster and back.  You can just set the time in that cluster.
GCentral
(4,945 Views)
That did the trick.  I did find I have to set the hour to 1 to get 12:00 AM setting it to 0 it thought it was the day before.
Thanks!
Dan Shangraw, P.E.
(4,935 Views)
That sounds like a Time Zone issue.  I know there are options in there for UTC or not.  Might want to make sure those are set to not be UTC.
GCentral
(4,903 Views)
Thanks for the tip.
I set UTC to True and was able to set the hour to 0
Thanks so much!
Dan Shangraw, P.E.
(4,898 Views)
