Time stamp writing two lines
I thought I had this problem sorted out but apparently not.  My code is writing the time stamp twice every few lines offsetting the data in that row while a row or two lower it copies an identical time stamp as the one preceding (instead of increasing incrementally).  If you take a look at the attached .csv file it should be clear what I am talking about.  I am trying to convert waveform data to a string and write to a .csv file.  Any suggestions on why this is occurring would be greatly appreciated.  Strangely (to me, at least), this data is all collected at <1 Hz.  If I collect data at 1 Hz there is no time stamps issue.  Thoughts?
Thanks in advance.
(2,532 Views)
to better understand your problem...please post your VI
(2,530 Views)
(2,528 Views)
it might be because your loop is running 100%, add a wait ms wired to a constant
(2,521 Views)
