Time stamps of string data read via VISA
Hello!
I am trying to read data from a mass flow meter (Omega FMA-1600A), timestamp the data and record it in a txt file. What I did was to read the data through a VISA serial port, limit the bytes of reading per cycle and via string combination to put everything together in a new row of data which includes the timestamp. However, the timestamp is still inserted at random locations, so it splits numbers (e.g. 0.0.36 565) and I can't seem to put it in the beginning. Do you know what I could do to avoid this?
Thank you!
(2,366 Views)
With the information you have provided (not) I can say with confidence, the answer to your question
Is
Fix your code.
Id you want a more useful answer please share the code you have trouble with and somebody should be able to help you.
Ben
(2,356 Views)
@ttoshkov wrote:
Hello!
Thank you!
They're not "random" locations.  It just seems that way because you haven't fully understood the way to communicate with the instrument.  Carefully read the manual where it shows how to communicate with the instrument.  Feel free to upload the manual so we can prepare for your questions.
Bill
CLD
(Mid-Level minion.)
(2,352 Views)
