Time sync of PCI-1588 with PTP
I need to time sync my PCI 1588 card as a slave using PTP.
I know that the PCI-1588 card is receiving PTPv2 packets as I verified this with a Wireshark network capture on the interface.
I have set the priority less than the master but my 1588 card always wants to act as the master after.
Please give me any information on how I can get the PCI 1588 to act as a slave and time sync from my Tekron clock source. (see images attached).
Cheers.
Mitch.
(3,026 Views)
Hello Mitch,
To my knowledge, there is not a way to override the algorithm that chooses the most accurate clock to make the Master. In LabVIEW, there is a property node that may set the priority given a tie between the two clock sources.
(2,997 Views)
