Time taken for SIClear to clear input buffer
I am using a soundcard as a low cost DAQ device. I am having trouble with SIClear.vi, in that it's taking ~25s to clear 9s of mono input data taken at 11kHz and 8bits per Sample. This is (largely) independent of how many other things I have running on the computer.
Why does it take this long? Does anyone have any hints on how to speed it up?
Ross
(2,736 Views)
Ross,
I can advise you to check that you have appropriate size of input buffer.
Another thing that ussualy I work with SoundCard in the next sequence:
SIConfig - SIStart - SIRead - SIStop - SIRead - SIStop-SIClear.
The first "SIRead - SIStop" I use to read useful data, and the second "SIRead - SIStop" I use to empty the buffer before SIClear.
Hope it will help you.
Oleg Chutko.
(2,736 Views)
