Timed Interval Reading VI
Trying to Execute reading values on a timed interval and then writing those values into a table.
I have attached our current set up. I am looking to take the Capacitance reading, a "user defined" amount of times over a "user defined" interval of time.
i.e.
1 reading every 10 seconds for 60 seconds
6 readings of Cap total over 1 minute
I have timers in there and I can't for the life of me figure out how to get the value I seem to be gernetaing for Cap to be output anywhere besides where it is currently going.
I hope to have the data readable on screen AND printable to paper but even if it just exports to excel nicely that will work too.
Thank you,
Josh
(2,674 Views)
Hi Josh,
Easiest solution: use a FOR loop set to iterate 6 times, with a 10000ms wait function inside next to your DAQ code…
No, you didn't…
(2,669 Views)
