Timed Loop in LabView RT cRIO
@jwscs: I realized that your examples are correctly set up.
But NoorForWind screenshot clearly shows that he set the timed loop to 2000 mikroseconds. That's only 2 ms, not 20 ms. So that's the reason for his confusion.
Regards, Jens
Kudos are welcome...
Message 11 of 12
(1,355 Views)
Two comments.
You have an indicator showing you that the previous loop iteration finished late.  That means it didn't get done in time within 2000 microseconds.
Also,  1000 microseconds is 1 millsecond, not 10 milliseconds.  10milliseconds= 10,000 microseconds.
Message 12 of 12
(1,342 Views)
