Timed Loop timing source - Control Loop From Task is too slow
I'm trying to make a Timed Loop run at a period of 2 ms, with an analog input task running at 50 kHz as timing source. The input analog signal is scaled and fed into a synchronised analog output task on the same multifunction DAQ board. Using the built-in 1 kHz or 1 MHz clock as timing source for the Timed Loop works great, except for a slight time lag between the loop and my AI/AO tasks which over time becomes unacceptable because my task will be running for up to an hour. However, when I use the DAQmx Create Timing Source: Control Loop From Task vi to create a timing source, everything slows down and the fastest loop time I can get is around 20 ms. Any suggestions to get around this would be highly appreciated!
System: LabVIEW RT 8.0 with DAQmx 8.0 running on an NI PXI-8186; NI PXI-6251 used for analog input.
Message 1 of 1
(2,817 Views)
