Timed Sequence Structure timing error
I am attempting to create two RF pulse waves, one at 90 degrees and the other at 180 degrees with a 2 second delay after the first pulse. I used this time sequence structure and believed that I followed the requrements but no matter what I change the second pulse occurs immediately after the first. Please let me know what I am doing wrong or if there is another approach to do this. Thank you.labview pic.png
(4,485 Views)
Please attach an actual VI, which allows me to look at everything without severe eyestrain.  It also allows me to "edit" the VI, test aspects of the code I might not understand, etc.
Bob Schor
(4,476 Views)
Instead of attaching a picture that is scaled down too small for us to see, please attach the actual VI.  That way we can experiment with it also.
(4,476 Views)
Sorry about that, I did not know that would be easiest for ya'll. This is my first time posting. Thanks for the quick response!
(4,468 Views)
Accepted by topic author Zturner94
Two things.  The delay function on the sequence structure is looking for a value in milliseconds, you are wiring in seconds.  So multiple by a 1000.
Second,  You are dividing your frequency  by your sampling rate and feeding that into sine wave generator.  Just wire in the frequency.
(4,463 Views)
