Timed Subvi run and stop for set time
I have a program cod controlling temperature, i need subvi run for 5 minutes and stop for 5 minuts continously to controll current source supplying heater around my sample by continous pulses of mA.
(2,764 Views)
Hello MaTaRaWeY
Could you be more specific, maybe use a VI with comments to help explain your problem better,
You may also like to look into the "Wait (ms)" node under the Timing Palette.
Derick Mathew
(2,733 Views)
