Timed data Loop
Hi
Need some help
I want to make 5000 samples of a value in 10 sec using a timed loop
Can anyone explain how?
(3,058 Views)
This is one of those times I would just use an express vi (Simulate signal.vi) use the simulate acquisition timing option and ignore the warning that the vi will take longer than 5 seconds to execute.
(3,049 Views)
The goal for this VI is to read a shared variabel from some NI Hardware(DAQ analog input channal)
I need to stor values from this DAQ channal using Timed Loop with 500HZ in 10 sec.
Those values stored in an array shall i use in anothee Sub VI calculating some mean values of this array
(3,047 Views)
Try this vi. This vi will run for 10 seconds and collect the data and put it in a queue and in the below loop it is being read so you can take the data from the below loop and write it to a file.
Good Luck
(3,023 Views)
Thx
I need a 2010 version is that possible? I dont have the 2011 version of labview
(3,013 Views)
Here is the vi in 2009 version.
(3,006 Views)
