Timeout error in TCP Read
If I timeout using the TCP read vi I get a timeout error, as I would expect. The problem is the error is in the form of a pop up window. Is there any way to suppress this? I just want to see the error in the error cluster and deal with it that way.
(2,874 Views)
Either wire up the error cluster that comes out of the TCP Read VI or disable automatic error reporting in the VI properties of your VI.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,869 Views)
