Timeout error in VISA read
I have been trying to communicate with my new Instec mk2000 temperature controller through a simple self wrote LABView program ( i am beginner) but getting Timeout error in VISA read.
I tried communicating in MAX. Write and Query work fine. But read shows error ( but works fine when called after write or query)
Here are some screenshots
ThanksBlockBlockMAXMAXFrontFrontIO MAX.JPGTimeoutTimeoutserial MAX.JPGwrite and read.JPG
(2,060 Views)
Hi kharkhua,
Do you know the meaing of those "\n" chars in MAX?
Do you know the difference between default display mode of a string control/constant and the "\-code"-display mode?
Do you know you can set the display mode indicator visible for a string control in its options?
Please make that display mode indicator visible. Switch to \-code display. Then write "*IDN?\n" into the string control. Then run the VI: most probably your device is expecting the LF char (aka NL aka newline aka "\n") as a TermChar and will only answer after receiving it…
(2,039 Views)
To elaborate a bit on GerdW's reply:
The \n in the VISA test panel represents a "newline" character.  The VISA panel shows control characters as "backslash codes".  It isn't helpful that the only way to know this is by someone telling you!
So when you send the *IDN?\n in the VISA test panel, it is actually sending the text *IDN? followed by a newline character.
So what does this mean for you?  In your code, you can either: use a text constant with its default settings and type in *IDN? followed by a newline character - the Enter key will do this for you - or you can set the constant's display mode to \ and type in the command exactly as it was displayed in the VISA test panel.
One very good habit to develop is, if you are displaying a constant, control, or indicator in a non-default way, make sure to make the display mode (for strings) or the radix (for numerics) so that people who look at the code - including yourself at a later date - know what they are looking at.
Bill
CLD
(Mid-Level minion.)
(2,010 Views)
Thanks gred for the response.
I know what '\n' means but i am not familiar with the things that you have mentioned in second and third questions.
Anyways I did change somethings ( not sure if correct ) but the error persists.
Thank you
(1,988 Views)
You need to set the Write string control to \display mode.  Then fix the string that you are sending.
(1,981 Views)
