Timeout for analog trigger
I've written a C program to control my PCI MIO 16E4 Daq Board using
asynchronous function.
The trigger is defined in Configure_HW_Analog_Trigger and the
aquisition is done with DAQ_Start.
I want to set a timeout to avoid the board waiting too long for the
trigger to occur but the only NIDAQ function that I've found in NIDAQ
is Timeout_Config which is used for synchronous function only.
Any help appreciated.
Greetings.
Claudio
(2,817 Views)
You are likely to get more responses to this question if you post in the Multifunction I/O category rather than the LabVIEW category.
I am also not seeing a timeout parameter for the asynchronous NI-DAQ functions, but there are ways to implement a timeout scheme. In the DAQsingleBufAnalogTrig.c example, you see that they call DAQ_Check in a loop to get the status of the analog operation. You could set your program to loop a fixed number of times and if the acquisition is still not finished and the number of retrieved samples is 0, you can conclude that a timeout has occurred. Or instead of setting a fixed number of loop cycles, you could keep track of the time elapsed using the Timer functions provided by your compiler environment.
(2,817 Views)
