Timeout property ignored in DB Tools Open Connection.VI
Very simple issue:
I am using the NI LabVIEW Database Connectivity Toolkit to connect to a remote SQL Server 2008 R2 database server.
Here is my connection string:
Provider=SQLNCLI10.1;Data Source=my_ip_address,my_port;Network Library=DBMSSOCN;Initial Catalog=my_database;User ID=my_username;Password=my_password;Connect Timeout=5;
It works fine.  Expect for the timeout property.  Note how I have specified a timeout of 5 sec in the connection string.  And I also specify a timeout of 5 sec when I call the Open Connection VI as seen below:
But the connection timeout is always around 20 seconds.  No matter what I do.  My timeouts are just ignored.
Any tips?
http://www.medicollector.com
(3,163 Views)
Any possibility that the connection is already open?
From the ADO reference:  The ConnectionTimeout property is read/write when the connection is closed and read-only when it is open
Are you sure this is supported by SQL Server 2008 ? Again, from ADO:  Make sure the provider to which you are writing code supports the ConnectionTimeout functionality.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,150 Views)
Thanks.  You are probably right about the provider.
(3,140 Views)
