Timer function
Dear all,
I'm trying to create a simple timer function that will execute a task for a certain amount of time, then stop for a certain amount of time and then repeat. I know it can be achieved by using a flat sequence structure along with the Wait (ms) block. However, it doesn't seem to allow adjustments to any controls when the task is active unless it's put in a while-loop. Which is why I did the following arrangement with an Elapsed-time-block which only does the job for one iteration since it keeps counting even though it's frame should be inactive, hence making the second iteration go on for 5-3 = 2 seconds (instead of 5 s). I'm all new to labview, is there anyone who could provide some tip on how to implement this simple timer function?
Best regards
Patrik
(3,803 Views)
Accepted by topic author Pagustaf
Wire a =0? function to the reset input of the timer function coming from the i node of the while loop.  That way the timer resets on the first iteration of the while loop.
(3,799 Views)
I sense the idea, but I can't figure out what "wire a = 0 function" and the "i node" means?
(3,795 Views)
Now I get what you mean - and it worked! Thank you sir.
(3,784 Views)
