Timer or similar
Hello all!
Im making a simple code to teste mathscript, but im having a problem/don't know how to do a timer.
The idea of the code is:
Im measuring 2 values of voltage (V1 and V2)
When V2 > V1, I want to wait like 10 seconds and then if V2 still higher then V1 i want to activate a boolean.
My only problem now is making this "timer" or "wait".
Can someone help me pls?
(3,076 Views)
Hi pedro,
using "plain" LabVIEW this would be very easy, so why do you use Mathscript here?
(3,071 Views)
This is the project
(3,064 Views)
Hi Pedro,
All the stuff in the MathScript node can be done by simple LabVIEW functions easily!
I really recommend to get rid of the MathScript…
The timer can be implemented using the ElapsedTime function.
(3,030 Views)
