Timestamp Representation
According to this (link), a timestamp is actually a cluster of two I-64 integers.  Is there a way to extract these integers from the timestamp without converting to a double taking the integer and decimal part of the result?
(3,756 Views)
The easiest should be typecasting, but I'm not sure whether typecasting to a cluster of 2 I64s will work. You might need 4 I32 and then play around with a bit using join, etc. Unfortunately, I can't check at the moment.
___________________
Try to take over the world!
(3,752 Views)
This is what you get using the TypeCast method:
Message Edited by smercurio_fc on 08-12-2008 05:07 PM
(3,741 Views)
I am trying to use a similar method to save data as fast as possible without having to convert into string first.. So, how does one get from the 3301423454.70794773 double precision number to the original timestamp Time/Date???
Many thanks,
Harry
(3,518 Views)
The numeric conversion palette has a To Time Stamp primitive.
___________________
(3,508 Views)
tst,
I realised that soon after I posted the question, but still thanks for the reply..
Harry
(3,461 Views)
