Timestamp along with acquired data in a binary file
Ladies and Gentlemen,
I am trying to add a Timestamp to some acquired data. The time stamp must be only one - when the file was created and in the beginning of the binary file. After that all the data should follow. Can anyone help and point out what do I need to do.
You can see from the attachment that I use DAQmx functions to create a TDMS file (without the time stamp - and I would like to keep the TDMS file for the moment) and then take the data and write it to the binary file (adding the time stamp). I haven't placed the triggers... I am just looking for the idea - what I am missing. I would like to keep the data the same (as taken from the graph) and just add the time stamp...
Thank you in advance!
MD
(2,659 Views)
(2,635 Views)
Thank you very much Carmen!
I fixed the time stamp in a similar way.
I have another question now... I am writing the data to tdms files and a binary file. In the tdms file the data is fine, but in the binary file I have time to time empty spaces. I am extracting all Y values and trying to write them in the binary file... (I am not sure if I am doing it right...) Please see the attached pictures.
MD
(2,617 Views)
